The NotcherF1.rvb I have drag dropped, and command line doesnt run it, as I am avoiding coding buttons to minimise time its taking to add in the buttons for V7 (1 whole week ), I am preferring to reference or just run command from the button, can this be made as a drag drop ?
I have gone for the referencing method:-
-_RunScript (D:\RHINO 3D WORK AND ASSOC FILES\Plug-ins and Scripts\NotcherF1_Helvetosaur\NotcherF1.rvb)
in a new button.
I run it in V7 and immediate error.
As for existing Notcher code…
I had set the gap to 0.003 in a small objects feet file and prior I did 0.005
I try again
V5
new>small objects feet. create two blocks rotate one at centre copy =yes, to get the second.
run the command by typing notcher into command line
select first object (horiz one in top view,)
enter 0.005 hit enter
select second and get
Notcher result 0.005 gap small Objects feet rhino v5 error before result.3dm (31.6 KB)
I see a notch but it isnt one !
V7
same process, no error but result isnt a notch.
Notcher result 0.005 gap small Objects feet rhino v7.3dm (247.5 KB)
What I don’t understand is why @Steve1 is insisting that this script is absolutely necessary to have in order to complete his installation…
I thought it would be an easy fix, but its taking too long. I may just give up on this Notcher and delete the button and move on.
We will have to go without, 170 others after it it seems.
I want to acronis the build of win10 , and get on with the remainder of 140 progs, before Christmas happens as I dont want to be still doing my build over Christmas, I did start this in July, then was told all hardware was great for win7 but with issues win10 was having, I was told it had to go for win10, so £1300 later (new MBd, CPU, GPU, ram, SSD’s, cooler, and 5 weeks later I am staring at the dreaded chance of no Christmas. V7 has taken 3 becoming 4 weeks to set up, everything done from scratch, as was suggested, no imports of .rui or such.
I dont want backups with things not working, my rule is only ever backup when all is ok, backing up non working aspects of a PC is wrong, one should be able to revert to a backup knowing all is right with it.
I also have Outlook2013 refusing to search sent items folder, even with help of Msoft.
Need to get recent Folders added back in after Msoft nuked that most vital feature, and also fix screen save not working, hate Msoft, win7 was fine.
so fix those and move on, so I hope.
I have never done backups with notes added to the file saying this and that not working, they are always all things working. win10 is proving a real pain.
Steve
