GUI Status Indicators
Hi All,
I’m still fairly new to GH, but I’ve been working on a large project for the last few weeks. I’ve tried a tonne of different things, but the common problem is that I forget what “shape” a data tree should be at key points i.e. what is valid and what isn’t .
I would like to specify simple tests, then visually indicate them in the GUI with a visual indicator - like a traffic light or similar. The best I can do at the moment is to do a simple test to get a true/false then output that to a panel - but it’s still too easy to miss a ‘false’ when you have lage models, so some coloured indicator would be nice.
To clarify, I’m referring to “False Valid” trees here… i.e. the tree might work with the components, but give a non-sensical output but doesn’t throw an error. I want to test for those inputs.
Any other relevant advice would be appreciated.
How about [PancakeContract].
https://www.food4rhino.com/en/app/pancakecontract
Yeah, I can see that being helpful. I like the ‘fast fail’ component… It would be tricky to catch everything while debugging, but once you know where your model is most likely to fail, you could add it in there.
