I am using the geometrygym-GSA. I was wondering if we can set the units and design code via grasshopper? And the ggcatalogueprofile from BullAnt always prompt an error when I run analysis in GSA. Will it create a problem to the model?
The active rhino document units are used to nominate scale, so that you get context in the viewport. So if you want to work in metres in grasshopper, activate a rhino document/template with metres (or similar with mm, feet etc).
What’s the error message? Maybe try updating Bullant from downloads page of www.geometrygym.com
