Grouping Lines in Paths/Branches based on the Connections
Hi there,
I have a series of curves that I would like to be able to group into individual paths/branches based on whether they are connected to each other (as in have them in branches {0},{1},{2} respective to their connections to other lines).
Curves to Group by Connection.gh (2.7 KB)
Hoping I can get a solution to this.
Thanks!
Getting there but there must be an easier way? I got the pink areas “joined” in the same branch but the remaining lines connected to the “islands” require three of them to be consolidated into the third branch ({2})… :thinking: I’ve had enough fun for now.
Curves to Group by Connection_2022Oct17a.gh (27.4 KB)
Hey, check this out.
Curves to Group by Connection_Re.gh (15.0 KB)
When you find yourself beating your head against the wall, take a break! You’re probably on the wrong path and a simpler idea will quickly occur to you. Works for me.
Curves to Group by Connection_2022Oct17b.gh (19.4 KB)
Check this as well.
Curves to Group by Connection_re.gh (13.7 KB)
Thank you for the reply!
Thank you all for the replies! The help was greatly appreciated!
