hi, I want to trim the brep inside the ramp by projecting the green overlap lines of the two brep vertically
To run Trim Solid, the extruded object must be closed, so I will need to run the sub curve command, but I do not know how to extract the curve
Please let me know if there is a way to trim the inner brep into a vertically extruded shape with a sub curve or another way.
