Is there any RhinoCommon function similar to the ‘PointGroups’ component in grasshopper, or it needs to be written from scratch?
Thanks in advance for your help!
I don’t think so?
but you could use Node in Code to achieve that.
cheers.
Hi Bob,
Thanks! I didn’t knew this.
But as I’m using RhinoCommon via a C# plugin, I won’t have access to this feature ![]()
Oh I think It’s totally possible in C# you’ll just use the Rhino.NodeInCode namespace and it’s a little different implementation. Check out this post: Using the NodeInCode namespace
Hi, not fully tested but does this do what you’re looking for?
using System;
using System.Collections.Generic;
using System.Linq;
using Rhino.Geometry;
Func<List<Point3d>, double, List<List<Point3d>>> point_groups = (pts, minDist) => {
var pointGroups = new List<List<Point3d>>();
List<Point3d> lonePoints = pts;
bool repeatLoop = true;
while (lonePoints.Count > 0) {
var inRangeGroup = new List<Point3d>{lonePoints.First()};
lonePoints = lonePoints.Skip(1).ToList();
while (lonePoints.Count > 0 && repeatLoop) {
repeatLoop = false;
var tooFarGroup = new List<Point3d>();
foreach(var lp in lonePoints) {
if (inRangeGroup.Any(p => p.DistanceTo(lp) <= minDist)) {
inRangeGroup.Add(lp);
repeatLoop = true;
else
tooFarGroup.Add(lp);
lonePoints = tooFarGroup;
pointGroups.Add(inRangeGroup);
repeatLoop = true;
return pointGroups;
G = point_groups(P.ToList(), D);
