Grasshopper player select subobjects
The grasshopper player geometry component can be set to accept only surfaces and then allows me to select BREP faces, which is what I want. But then it won’t process this face into the script. How can this be done?
Bump, I’m running into the same problem
Can you send me a sample? I just fixed this for getting Brep edges as curves and I suspect I need to do something similar for faces.
