Is it possible for the program window to remember it’s location when closed?
When I boot grasshopper, I typically have an external monitor. Currently, it always loads a new session or a new file within a current session on top of my rhino window regardless of whether or not another monitor is connected. I then have to drag it off the main screen to my second after it’s done loading, which occasionally takes several minutes with large files.
A secondary request is to be able to drag a widget from one place on the grasshopper canvas to another with drag velocity proportionate to the distance I drag the cursor off screen.
Thank you so much for this program! You all do amazing work, I am very very grateful for the tools you make.
I wish that Grasshopper window can be disconnected from Rhino window in such a way that:
When I click on Rhino window it does not put GH window on top of every other app I have opened.
When I minimize Rhino I want GH to be kept in its restored/maximized position. Sometimes I just need Rhino and sometimes I just need GH and if have a window with some book or data on the side it gets hidden, so I have to move GH window on top of Rhino window.
BTW, that second one should also be valid for RhinoPython editor.
just circling back to this.
I do see that the drag is proportional. however, I have a multi monitor setup and I find that the drag velocity implements when I drag far off the edge of the grasshopper window. since my screens aren’t the same resolution or orientation, when I move the cursor to another screen to speed the pan along, it will jump which makes the panning hard to follow.
