Grasshopper Explode Object fails due to clipping view
As the title says, the Grasshopper Explode Object fails when a linked file contains a clipping view.
A quick test isn’t showing this, but might not be understanding completely.
R8-LinkedFileExplode.gh (7.3 KB)
R8-ContainsLinkedClippedView.3dm (51.3 KB)
R8-HasClippedView.3dm (50.7 KB)
Sorry it’s happening with a linked file using the Import Model Block Definition component.
System Info
Rhino 8 SR10 2024-6-22 (Rhino 8, 8.10.24174.10001, Git hash:master @ 909420bcadde3f68c5c98a97037ffd3611e91473)
License type: Kommerziell, build 2024-06-22
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 22GB, Driver date: 5-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.55
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 5-23-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-23-2024
Driver Version: 31.0.15.5255
Z-Buffer depth: 24 bits
Total Video Memory: 23028 MB
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\KeyShotRhinoPlugin (78243fe3-17a0-4865-b713-88b4c224c48c)\1.5.0.0\KeyShotRhinoPlugin\KeyShotRhinoPlugin.rhp “KeyShotRhinoPlugin” 1.0.0.0
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.10.24174.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.10.24174.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.10.24174.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.10.24174.10001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.10.24174.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.10.24174.10001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.10.24174.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.10.24174.10001
Got it, thanks for reporting RH-82898, it looks to be related to the clipping plane, active or not.
RH-82898 is fixed in Rhino 8 Service Release 9
Thanks Brian. I’m using a dujour build it’ll take a moment until I can test it…
Rhino 8 SR10 2024-6-22 (Rhino 8, 8.10.24174.10001)
Or what would I have to do to overwrite the dujour 8.10… with the current public release?
You need to uninstall and reinstall to get an older build of the latest RC.
