all the plugin icons just got lost from the the components tab in grasshopper what to do?
Hi Kushal,
In windows you can do a repair install of Rhino. Go to Add or Remove Programs > Rhino 8 > Modify > Repair
Hi Mohamed,
Try starting Grasshopper via the Rhino command line with GrasshopperLoadOneByOne and say no to 3rd party gh plugins.
What is your About info?
Nope i have tried ,repair, and reinstalling rhino , reset settings but none worked
What is your Rhino SystemInfo?
Did you try starting Grasshopper from the command line with GrasshopperLoadOneByOne and say no to 3rd party gh plugins.
Hello, I have exactly the same problem.
I tried:
1)Repairing rhino 8
2)Deinstalling Rhino 8, restart PC, reinstall Rhino 8
3)Starting Grasshopper from the command line with GrasshopperLoadOneByOne
and they all have no result.
On Friday 25th March it was good. On Sunday 27th of March the problem started.
All the commands are there in Grasshopper because double-clicking on the canvas and typing a command will give you a list to choose from and the will pop up and can be used. It is only that all the icons in the groups will not show up, only the “Param” group.
When I use Rhino 7 , grasshopper starts normal.
Please run the SystemInfo command in Rhino 8 and post the results. Thanks
Okay Japhy
Here it is:
Rhino 8 SR18 2025-4-10 (Rhino 8, 8.18.25100.11001, Git hash:master @ 5d157e876c23ece334d9c8666b8513ffc6d4a98d)
License type: Educational Lab License, build 2025-04-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 63GB)
.NET Framework 4.8.4780.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 1-20-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3080 Laptop GPU (NVidia) Memory: 16GB, Driver date: 12-8-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.88
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-8-2021
Driver Version: 30.0.14.7288
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Program Files\SimLab\Plugins\SimLab GLTF From Rhino\SimLabGLTFExporter.rhp “SimLab GLTF Exporter”
C:\Users\mko\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Iris\0.7.1\Iris.V7.rhp “Iris” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.18.25100.11001
C:\Users\mko\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.18.25100.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.18.25100.11001
Any particular reason you are using .Netframework?
Video driver updates are available. Driver Results | <dd~ProductName> | <dd~OSName>
We’ll want to test without 3rd party plugins. Either by opening Rhino in Safe Mode or disabling via Properties>Plugins, then restarting Rhino.
Hello Japhy
I did all the things you suggested but the problem persists.
- Disabled .Net Framework
- Installed updated nvidia drivers
- disabled 3rd party plugins
- restarted laptop after each change
What else can I do?
And thanx for your help
Marc
Can you post the updated SystemInfo? Thanks
Here it is.
Strangely it says that .Net Framework is still active, although I disabled it
Could it be that the settings in Grasshopper preferences got something to do with it?
Rhino System Information.txt (2.9 KB)
That is not a windows feature you want to turn off.
Run the SetDotNetRuntime command to switch (restart Rhino req’d)
Okay
I ran the SetDotNetRuntime command to switch, activated the .Net framework again & restarted Rhino. Problem in Grasshopper persists
ideally the system info should look be on 8.0.14, is that the case?
Rhino 8 SR20 2025-4-25 (Rhino 8, 8.20.25115.10001, Git hash:master @ 20b43256bd826988cbf7973fffd80164d23de83a)
License type: Commercial, build 2025-04-25
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.14
Nope!
Hello Japhy
I did this:
"To set the .NET Core version once:
- Create a new shortcut for Rhino in Windows
- Edit the shortcut
- Add command line argument /netcore-8"
And now grasshopper works fine
thank you for your help!
Marc
Hello Japhy
when unload 3rd party , it loads properly
About info
Rhino.Inside Revit: 1.32.9246.15288 (2025-04-25T08:29:36)
[Expanded Information]
Rhino: 8.19.25112.13001 (Rhino 8)
Revit: 2023.1.60 (23.1.60.36)
CLR: 4.0.30319.42000 (4.8.9300.0)
OS: Microsoft Windows NT 10.0.26100.0
After going throw each plugin , it is OpenNest 2.11.0.0
