Currently I’m trying to use Karamba3D for the first time. While doing a tutorial a error occured when trying to use the “LineToBeam” node.
Does anyone know how to fix this? (see printscreen below)
Changed to #grasshopper-karamba
Hello H12dirksliepenbeek,
I haven’t seen this error yet. What version and build of Rhino/Grasshopper/Karamba3D do you use?
Could you make the ‘Method’-column a little bit wider, so that the method names are fully visible?
Best,
Clemens
Hi H12dirksliepenbeek,
could you send me the Grasshopper definition which causes the problem?
Best,
Clemens
It is the “Line to Beam” definition, same for “disassemble element” definition.
which version and build of Karamba3D do you use? In order to see this information place a ‘License’-component on the Grasshopper canvas and read its output via a panel-component.
Does the problem occur also with other components like e.g. ‘ModelView’?
Best,
Clemens
the reason for the problems could be, that you haven’t installed Karamba3D in the default directory which is ‘C:\Program Files\Rhino 6\Plug-ins’. Try to use the standard installation path.
Best,
Clemens
Thanks you! The problem is solved with re-installing it on the right location
