Grasshopper Align Vertices component
Hi. I guess that the Align Vertices component should operate as the Rhino AlignVertices tool but it doesn’t. As you can see with the same Distance to adjust parameter of the Rhino AlignVertices tool and Alignment tolerance parameter of the Align Vertices component I get different results. While the Rhino Align Vertices tool works absolutely predictable the component works weirdly, I actually can’t understand how it works by changing the Alignment tolerance value.
Alignment.gh (2.4 KB)
@DavidRutten It seems neither except you don’t know work how it actually works. Could you clarify that?
I just opened your file and hid the input mesh. What units and tolerance are you using in Rhino?
@martinsiegrist
I believe the default…
Do you have the same?
It is weird for me :astonished: Why does the component work for you? I guess if there would be a problem with tolerance/units it wouldn’t work for Rhino as well but it works with the same parameter value.
Same tolerance.
Your system info might be useful for developers
I get same result as @sadovshikov
My SystemInfo
Rhino 7 SR14 2021-12-14 (Rhino 7, 7.14.21348.13002, Git hash:master @ 5ab502b613f84488d00228948505c6f28ebfe598)
License type: Commercial, build 2021-12-14
License details: Cloud Zoo
Apple macOS Version 11.6 (Build 20G165) (Physical RAM: 32Gb)
Mac Model Identifier: iMac15,1
Language: en-US (MacOS default)
AMD Radeon R9 M295X OpenGL Engine (OpenGL ver:4.1 ATI-4.6.20)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: AMD Radeon R9 M295X
Displays: iMac (173dpi 2x)
Graphics processors
AMD Radeon R9 M295X (4 GB)
iMac (2048 x 1152)
USB devices
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
Hewlett-Packard: HP LaserJet P1006
Wacom Co.,Ltd.: Wacom Wireless Receiver
Bluetooth devices
Apple: Apple Wireless Keyboard
Apple: Apple Wireless Trackpad
Apple: Apple Magic Mouse
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/Users/Kevin/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot9Plugin.rhp/libkeyshot_rhino_plugin.dylib
/Users/Kevin/Library/Application Support/McNeel/Rhinoceros/packages/7.0/OpenNest/1.5.1/libsimpleDYLIB.dylib
/Users/Kevin/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot9Plugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
/Users/Kevin/Library/Application Support/McNeel/Rhinoceros/packages/7.0/ProRender/1.0.1.0/ProRender.Mac.V7.rhp “ProRender” 1.0.1.0
/Users/Kevin/Library/Application Support/McNeel/Rhinoceros/packages/7.0/EleFront/4.2.2/ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
/Users/Kevin/Library/Application Support/McNeel/Rhinoceros/packages/7.0/AMDDenoiser/0.5.3/AMDDenoiser.Mac.rhp “AMDDenoiser.Mac” 1.0.0.0
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.14.21348.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.14.21348.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.14.21348.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.14.21348.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.14.21348.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.14.21348.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.14.21348.13002
-Kevin
Hmm, I am not alone? Can someone check as well for yourself?
It’s really interesting how does it work for you… @martinsiegrist
Please post your system info:
System Info
Rhino 7 SR14 2021-12-14 (Rhino 7, 7.14.21348.13001, Git hash:master @ 5ab502b613f84488d00228948505c6f28ebfe598)
License type: Kommerziell, build 2021-12-14
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 1.3e+02Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 12-6-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 472.84
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2021
Driver Version: 30.0.14.7284
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.4.0.0\KeyShot9RhinoPlugin\Rhino 7\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.4.0.0
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.14.21348.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.14.21348.13001
Not using a mac.
Thanks. Seem it’s happening with the mac version only
