Grasshopper 2 --- stuck at launch ---
Hello fellow rhino users,
After a certain update in the previous months Grasshopper 2 stopped launching for some reason. The main banner seems like everything is working well but then the canvas doesn’t open. After the last WIP update now it is stuck at %7.
What do you think might be the solution?
Hi Erdem -
Please run the Rhino SystemInfo command and copy-paste the result here.
Here it is Wim! Thanks in advance.
Rhino 8 SR0 2023-9-5 (Rhino WIP, 8.0.23248.12305, Git hash:master @ 911d9b123ed243f28caa260da41f22e0d3383b5a)
License type: Educational, build 2023-09-05
License details: Cloud Zoo
Expires on: 2023-10-20
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-13-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.68
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-13-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.68
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 12-12-2022 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-13-2023
Driver Version: 31.0.15.3168
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\justi\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Grasshopper2\2.0.8645-wip.22346\Grasshopper2Plugin.rhp “Grasshopper2” 2.0.8645.22346
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.0.3.0
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23248.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23248.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23248.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23248.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23248.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23248.12305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23248.12305
@wim reminded me that there is a bug when the screen scaling is set to 150%. Can you modify your monitor to either 100% or 200% and then restart Rhino and try again?
I tried it, still stuck at 7%.
I run the command “-G2” to see if there are any settings and I changed the “Load Plugins” setting from “StandardPlugins” to “AllPlugins”.
1213
Now it is not stuck at 7%. It goes all the way but still the G2 canvas doesn’t come up.
Please run the G2PluginViewer command on a fresh Rhino and manually load all the plugins by clicking on the Scoped buttons. Does the G2 command now show the editor?
Hello David,
Unfortunately, nothing changed. I will install the R8 Beta and try it now…
I uninstalled the existing Rhino WIP then installed the new Rhino 8.
I am using the “OptionsExport” and “OptionsImport” commands to migrate my settings. Maybe there is something wrong with my settings. Is there a way to go back to the default settings?
Hi Erdem -
There’s the Reset command that lets you do that.
No luck… Maybe it is a windows issue…
A side question, does Rhino work better on a Mac?
I’d say Rhino works better on Windows. meanwhile many fundamental things have changed in Rhino 8, which may bring issues.
