Grasshopper 2 Plugin Development
I am learning plugin development for Grasshopper 1. I made a component from the Grasshopper 2 sample file, but I cannot figure out how to use the new way of making icons for components.
[assembly: PlugInDescription(DescriptionType.Icon, “Grasshopper2_PlugIn.Icons.plugin.ico”)]
I think someone has been able to do this. @t.schwartz It seems that you were able to do this.
@martinsiegrist Would you be able to help with this topic?
I don’t make plugins
@martinsiegrist
Not a problem. I was thinking along that path, but I thought it would be a good thing to ask you. Thank you for the well wishes. It is good to get an instance to speak to a significant contributor.
@martinsiegrist
I was able to get it solved with the help of @gankeyu
Thank you.
You might see this:
If you wish to use the second method, override the IconInternal via AbstractIcon.FromResource / FromBitmap();
protected override IIcon IconInternal => AbstractIcon.FromResource("YourIcon.ghicon", typeof(YourComponent));
Remember embed the icon file in the project.
