Hi all,
This is a small trouble I am having when I am trying to communicate with a python script and a GHPython script using TCP Socket communication. the respose gets freezed, delayed or not responsive after 2-3 iterations.(attached screenshot) Somehow the server won’t send the data back and the client wont finish communication with the server. But when I run the same script through 2 terminal windows they communicate perfecty.
But when i try the same with UDP it works perfectly. Previously we have used TCP Socket communication to read data from a UR10 and it worked perfectly. I have attached the files here.
Can anyone tell me what could be the issue here?
P.S. I have also found a paper where it suggests that GH does not support socket programming over TCP protocol.
Link to the paper.
Thank you
