Hi - I’m not sure I follow - a single % value for a color? A left item?
Is this the Colour Swatch component that you are talking about?
What version are we talking about? Run SystemInfo and paste the result here…
So far I see it works if I change the item at 0% , but I need less colors so I have dragged a few on the left side to remove them , after this the item at 0% cannot be changed anymore
I haven’t played around with the Gradient parameter much but from a brief test…
Dragging a color point to the left side doesn’t remove it. It will just stack it on the left side. Then selecting the left-most color point will select the one of the stacked points that is most to the left but that point doesn’t influence the gradient anymore since a “less left-most” point was put on top of it. So, changing its color won’t have any visible effect.
To remove a color point, you need to drag it either up or down off off the gradient.
