Gradient Density of Gyroid Lattice
Hello all,
I have already created a gyroid lattice structure using the Weaverbird and Millipede plugins. However, now I am trying to create a gradient density (low density to high density) from top to bottom. I can’t seem to figure out how to do this, I tried to separate the layers and give them different thicknesses, but then I am not sure how to mate the surfaces or to create a smooth transition between those two layers’ densities. Is there a more efficient way to achieve this?
Any help is much appreciated!
Thank you,
Dylan
Hi Dylan,
Have you solved it ? I now also encountered this problem. Looking forward to your recovery.
Thank you,
Cris
It could be very simple but not very efficient with Dendro, here a thickness from 1 to 5 changing linearly with Z
gyroid change thickness.gh (17.7 KB)
I’m new to GH but looking to do something similar but with a different style of lattice (instead of gyroid). Was just wondering if somone could explain the main stages of this solution? Like what each bit does in dumb dumb language.
Hello Laurent, I just want to say how important you are to the Rhino community. Your replies to almost all the questions I coincidentally have are life saving.
Thank you
This helps a lot. Is there a way to have a nonlinear gradient? say along a curve or function?
It is more like that
gyroid change thickness.gh (17.6 KB)
Thank you
Hi there, im in the same place you were, by any chance did you figure that out? im also trying to use different lattice structures for gradient density. I will apreciate any clue! thanks
