Google Maps Api
Please is there anyway to import the googlemaps module into ghpython? Or that is not possible at this time?
Thanks.
Hi @aononye,
did you try installing it into a location known to sys.path and importing it?
Thanks,
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
Thanks for your response Glullo.
I have little knowledge about package installation except using “pip install”. However, i added the folder location to the module search path. Still nothing.
Hi @aononye
I went a stretch further and made this work for you. To make it work:
  • You will need to unzip the files into a folder (if you don’t change my definition, it needs to be the Desktop, inside another folder called “googlemaps”). Watch out! There are 2 folders called googlemaps, one inside the other.
desktop
googlemaps.zip (483.2 KB)
googlemaps.gh (3.3 KB)
  • It should then work as it does here. You’ll need to parse the results.
I hope this helps,
Thanks,
Giulio
Giulio Piacentino
giulio@mcneel.com
Thanks Giulio!
Not sure why i am getting this error.
I looked online and i saw it has something to do with the link below but not sure how to make this change. Rhino 6 is currently running on ironpython 2.7.5. I also reinstalled ironpython.
You need to enable frames in IronPython via the _EditPythonScript options.
Giulio you have been rely helpful. Thanks.
Another error showed up. not sure why.
I am not sure why. Maybe try downloading and placing that module into the same folder.
hi @piac , thanks for this.
if it’s not too much to ask, could you point us to how to parse the results and get a 3D in Rhino?
Thanks,
Olivier
