I am learning how to write code in GHPython.
I am trying to iterate over a data tree collecting curves, find periodic curves, close them within the tree, return the tree with all closed curves.
Printing out crv after the conversion to list shows that it’s just one PolyCurve in a list. I don’t know why, possibly a bug in treehelpers @piac ?
As a workaround you could loop directly over the tree without converting it, like so:
a = []
for i, branch in enumerate(crv.Branches):
for j, item in enumerate(branch):
if rs.IsCurveClosed(item):
bool = "closed"
a.append(item)
else:
bool = "periodic"
pts = list(rs.CurveEditPoints(item))
pts.append(pts[0])
a.append(rs.AddInterpCurve(pts,1,2))
Note, that you have to set typehint to ghdoc if you want to use rhinoscriptsyntax!
Original code works with these changes (and changing input type hint to ghdoc as @efestwin pointed out):
import ghpythonlib.treehelpers as th
crv = th.tree_to_list(crv, lambda crv: crv)
a = []
for i,branch in enumerate(crv):
for j,item in enumerate(branch):
bool = "closed"
a.append(item)
else:
bool = "periodic"
pts.append(pts[0])
