with sub-object materials applied to a single Brep, can I access the Material information somehow? I tried using GetMaterial as suggested here link, but I don’t think I understand how to get a ‘RhinoObject’ from the BrepFace in GH?
import scriptcontext as sc
import Rhino
sc.doc = Rhino.RhinoDoc.ActiveDoc
for guid in _guids:
brep = rs.coercebrep(guid)
for face in brep.Faces:
compo_index = Rhino.Geometry.ComponentIndex(
Rhino.Geometry.ComponentIndexType.BrepFace,
face.FaceIndex
# This doesn't work....
# 'face' needs to be a 'RhinoObject' ?
Rhino.DocObjects.RhinoObject.GetMaterial(face, compo_index) #<--
sc.doc = ghdoc
If anyone has any thoughts I would appreciate it!
thanks so much, @ed.p.may
I am able to get the Materials that way, sort of. If I do something like this:
import Rhino
for i, guid in enumerate(_guids):
print '- '*10, 'Looking at Brep {}'.format(i), '- '*10
print 'Using Guid: "{}"'.format(guid)
brep_obj = Rhino.RhinoDoc.ActiveDoc.Objects.FindId(guid)
print 'I found a "{}" with name="{}"'.format(type(brep_obj), brep_obj.Name)
brep_obj_mat_index = brep_obj.Attributes.MaterialIndex
print 'The BrepObject has a MaterialIndex of: {}'.format(brep_obj_mat_index)
mat = Rhino.RhinoDoc.ActiveDoc.Materials[brep_obj_mat_index]
print 'and a Material of: {}'.format(mat)
# This part can't be right?
for k in range(4):
mat_guid = mat.MaterialChannelIdFromIndex(k)
print ' The MaterialChannel: {} has a guid of: {}'.format(k, mat_guid)
child_mat = Rhino.RhinoDoc.ActiveDoc.Materials.FindId(mat_guid)
print ' which yields a Material: {}'.format(child_mat)
with a scene with two objects, each of which has sub-object materials assigned:
but the part I am still unsure about is how to find the right Channel Index on the Material to get? As you can see in the above, here I’m just walking through 0-4 and testing those Index’s on the material… There must be some way to see which Channels are used on a specific Material, no?
If I try and get the BrepFace’s MaterialChannelIndex, it always only yields 0 or 1 in this case…
