Hello Forum, I am currently facing an issue with a GhPython script I am developing, specifically with maintaining my data structure when trying to divide curves to obtain their points. The script either returns a flat list or generates nested lists in the form of “System.Collections.Generic.List” that I am unable to extract properly.
I am attaching the relevant portion of the script below, which is the last part where the issue occurs. I would appreciate any insights or suggestions you might have.
Here is a snippet of my current code:
# Create DataTree for the divided points
Divide_Points_1_tree = DataTree[object]()
# Define the number of divisions and kinks parameter
count = 4 # Number of divisions
kinks = False
# Iterate through the branches of Explode_1_tree maintaining the structure
for i in range(Explode_1_tree.BranchCount):
branch = Explode_1_tree.Branch(i)
path = Explode_1_tree.Path(i) # Maintain the DataTree structure
divided_points = []
for curve in branch:
# Divide the curve into points with the same parameter
divided = gh.DivideCurve(curve, count, kinks)[0] # We only get the points
# Ensure the output is a list and extract properly
if isinstance(divided, list):
divided_points.extend(divided)
else:
divided_points.append(divided)
# Add to the DataTree while maintaining the original hierarchy
Divide_Points_1_tree.AddRange(divided_points, path)
Custom = Divide_Points_1_tree
Ghpython_Problem.gh (18.2 KB)
In this script, I am attempting to pass data that initially comes out nested within a “System.Collections.Generic.List” from the output. When I try to use this data in another script as shown above, it still remains nested in lists of lists. How can I mitigate or fix this issue in a Python script to ensure a cleaner and more manageable data structure?
Thank you very much for your time and help.
Best regards,
Henry ![]()
