Hello
I am trying to make a grasshopper component using GHpython. I don’t know how to compile the code as there is no such an option. Also, there is an error message that can’t import copmonentbase from ghpythonlib !
Typo in componentbase ?
no, not at all.Even when I try a file made by Giulio Piacentino the same error occurs.
Can you explain more detailed, what you mean by “Compiling” in that context?
ghpythonlib.componentbase was only added in GH on Rhino 6, so that might be ur issue
EDIT: misunderstood your original question
have you read this? It describes how to switch to SDK mode and then compile a component.
