I have a strange problem trying to use a ghcomp. to evaluate a curve at parameter 0.
I have just finished a script where I’m using the same ghcomponent code evaluating at the start of a curve, and it works fine there, with the same sort of input, curve and 0 parameter.
Then I tried to do it in Grasshopper just with actual gh components, and that works.
I also tried with rhinoscriptsyntax and that works too.
I know, I should be using rs but Im much more in my comfortzone using gh components, since I know the in and outputs from actual GH use and I can also recreate some of scripts on the side on the canvas.
I am on Version 6 SR8
(6.8.18240.20051, 08/28/2018)
company pc, so not sure I can update.
however its strange since I used the exact same code in another script earlier, evaluating at the same parameter, 0, and that works fine. Now I just get Null values.
Unless you can update, there is not much I can do. A fix would come in an update anyways.
Also, it’s likely this got fixed in a SR. We published a couple of important upgrades for this library since SR0, and this might have been part of the fix.
