Evaluate Curve not returning point object
Hello I am not good at programming, but I am just learning.
Anyway I am trying to get the ‘evalute curve’ function to work like it does in grasshopper. Here is my code thank you in advance:
plane = rs.WorldXYPlane()
rectangle = rs.AddRectangle( plane, 10, 10 )
explodeCurves = rs.ExplodeCurves(rectangle, [0] )
crv1 = explodeCurves[0]
#curves = crv1,crv2,crv3,crv4
domain = rs.CurveDomain( crv1 )
print “curve domain:”, domain[0], “to”, domain[1]
#domain is 0 to 10 but I would like to reparamaterize it or unitize it.
pointOnCurve = rs.EvaluateCurve( crv1 , 3, )
ALso, I am not sure why I cannot evaluate multiple curves at the same time?
This should be:
curves = explodeCurves[0,1,2,3]
rs.EvaluateCurve(curves, .33)
@brobes05,
to avoid to unitize the curve(s), you might use
rs.CurveParameter(curve, 0.33)
see if below code helps:
def DoSomething():
    rectangle = rs.AddRectangle( plane, 10.0, 10.0 )
    explodedCurves = rs.ExplodeCurves([rectangle], True)
    for i, curve in enumerate(explodedCurves):
        domain = rs.CurveDomain(curve)
        print "curve {} domain: {} to {}".format(i, domain[0], domain[1])
        parameter = rs.CurveParameter(curve, 0.33)
        point_on_curve = rs.EvaluateCurve(curve, parameter)
        rs.AddPoint(point_on_curve)
if __name__=="__main__":
    DoSomething()
c.
Hello Clement thank you for your prompt reply.
Your code does what I wish to achieve and more as I don’t understand the ‘enumerate’ concept. I know its like a king in a card deck, but that is where I am lost.
My question is how can I reference the points created from ‘rs.Addpoint(point_on_curve)’ without using a ‘GetObject()’ function so that I can draw a polyline etc…
Thank you very much for your response.
Erik
Hi @brobes05, it is just a counter which enumerates the curves with a number, in the above example it is the variable named i… Here is one example without it, it appends points to an empty list, to create a polyline:
def DoSomething():
    pts = []
    for curve in explodedCurves:
        pts.append(point_on_curve)
    # for a closed polyline, add first point to end of pts list
    pts.append(pts[0])
    rs.AddPolyline(pts)
    DoSomething()
c.
Thanks for the reply. This is much closer to the level I am currently on. I am trying to force python into grasshopper which is not working out so well. Anyway, I coming up with the error ’ unable to draw polyline’. I believe I have written down the proper text. Thanks again for all your help. I understand much better now. The 2nd through 5th lines are indented in python, but I cannot get them to cooperate here.
def EmbeddedQuad():
rectangle = rs.AddRectangle( plane, 10,10 )
pts = []
    parameter = rs.CurveParameter(curve,.33)
    rs.AddPolyline(pts)
EmbeddedQuad()
Yes, the forum sometimes has probs with indents and empty lines. Below should work from within the Python editor. You can open it using _EditPythonScript command and paste. Note that i have indents even in the blank lines.
def EmbeddedQuad():
    pts = []
        parameter = rs.CurveParameter(curve,0.33)
    polyline = rs.AddPolyline(pts)
    if polyline: rs.SelectObject(polyline)
EmbeddedQuad()
Ps: to post python code on discourse, check for blank lines first than start the code block like this:
```Python
then paste your python code and end the code block like this:
Everything between should display with code style font and a few colors. :wink:
c.
Wonderful. You have been very helpful to me. I have much to learn and must try and stop forcing the language to work like grasshopper.
Thanks again,
Erik
