Hello, for rhino3dm meshes there is the rhino3dm mesh.toThreejsJSON method. How should it’s “reverse function” rhino.Mesh.createFromThreejsJSON() be called?
Documentation: https://mcneel.github.io/rhino3dm/javascript/api/Mesh.html#.createFromThreejsJSON
When using the result of mesh.toThreejsJSON or threejsmesh.toJSON as argument in createFromThreejsJSON, I get undefined as result.
I’d have provided a working example on how to do it, but coudn’t make it work due to CORS.
Nevertheless, here is my edited example from https://github.com/mcneel/rhino3dm/tree/master/docs/javascript/samples/viewer/01_basic
basic_example.html (4.0 KB)
fraguada
(Luis Fraguada)
October 26, 2020, 10:32am
2
We have an example that uses the rhino.Mesh.createFromThreejsJSON()
method: https://github.com/mcneel/rhino3dm/blob/master/docs/javascript/samples/compute/clash_detection/app.js#L71
If you don’t mind a bit of cpp, you can always check out the source here: https://github.com/mcneel/rhino3dm/blob/master/src/bindings/bnd_mesh.cpp#L364
So the call expects an object with the following structure: {data: bufferGeometry}
So your line 50 should be
rhino_mesh = rhino.Mesh.createFromThreejsJSON({data: threeMesh}); // CHANGED
Give that a try and let us know if it works for you.
Hello Luis,
thanks for your quick response!
Your example works indeed, but it does not with my own THREE mesh. I can visualize my THREE mesh in the canvas, so it’s probably not broken I think.
What could be a reason for this error?
fraguada
(Luis Fraguada)
October 26, 2020, 11:39am
4
You might be passing the whole threejs Mesh object (derivative of THREE.Object3d) when you should be passing the geometry (THREE.BufferGeometry).
Try threemesh.geometry
rhino_mesh = rhino.Mesh.createFromThreejsJSON({data: threeMesh.geometry});
Yes, that’s it!
Thank you
