GH sc.sticky change event / call python code components from another python component
I would like to load and save a configuration from and to a file in Grasshopper using python, which works, apart from the right save function trigger.
Once loaded, the configuration is saved in a dict in the sc.sticky. The config file should automatically (without for example pressing a button) reflect changes made to the configuration, but I don’t know how to properly trigger the save function.
Right now, I am using a Timer-component to periodically trigger a save config python component.
I checked if there is an event that I could use for this (https://developer.rhino3d.com/wip/api/grasshopper/html/N_Grasshopper_Kernel.htm), but I didn’t find a suitable one. Additionally, it doesn’t seem like one can even use these events from Python, only from VB and C#. Is it possible in GH to call python from a VB or C# script?
Another solution would be calling some python component from another python component. I did not find anything on this here either.
Of course, I could trigger the update directly by connecting all of the components, but I’d rather not do this.
Thanks
from scriptcontext import sticky
id = ghenv.Component.InstanceGuid
if sticky.has_key('i'):
   a = sticky['i']
comp = ghenv.Component.OnPingDocument().FindObject(id, False)
sticky['i'] = v
comp.ExpireSolution(True)
UpdateById.gh (9.7 KB)
Hello Mahdiyar, thanks for your answer! :smile:
How fragile is this solution? When copying these elements from one file to another, the ids change, if you copy them as a cluster they ids stay the same. Is this generally true?
I think a version which is using named groups (that’s the way Rhino computed identified elements too as I learned today) would be more robust.
Unfortunately I haven’t found a way to find out which Grasshopper groups a component is part of yet.
I checked the forum for solutions (Is there a way to accesss groups-information in an object? this one is talking about Rhino groups, not about GH groups), but coudn’t find anything on it.
Thanks again!
#ID
sticky['i'] = v
#Name
sticky['i'] = v
for obj in ghenv.Component.OnPingDocument().Objects:
    if obj.NickName in names:
        obj.ExpireSolution(True)
#Group
import Grasshopper as gh
def FindPythonObjectInCurrentGroup():
    pythonObjects = []
    ghObjects = ghenv.Component.OnPingDocument().Objects
    for obj in ghObjects:
        if type(obj) is gh.Kernel.Special.GH_Group:
            if obj.ObjectIDs.Contains(ghenv.Component.InstanceGuid):
                group = obj
                    if ghenv.Component.ComponentGuid == obj.ComponentGuid:
                        if ghenv.Component.InstanceGuid != obj.InstanceGuid:
                            if group.ObjectIDs.Contains(obj.InstanceGuid):
                                pythonObjects.append(obj)
    return pythonObjects
sticky['i'] = v
pythonObjects = FindPythonObjectInCurrentGroup()
for obj in pythonObjects:
Update.gh (9.1 KB)
Thank you very much! :+1:
Hello! I know that this is a python post, but I was trying to create something similar in C# with a sender component to a clustered receiver, can anyone help me plaese?
Sender:
using System;
using Grasshopper.Kernel;
public class SenderComponent : GH_Component
    public SenderComponent() : base("Sender", "S", "Send numeric data to receiver", "Test", "Data") { }
    protected override void RegisterInputParams(GH_InputParamManager pManager)
        pManager.AddNumberParameter("Data", "D", "Numeric data to send", GH_ParamAccess.item);
    protected override void RegisterOutputParams(GH_OutputParamManager pManager) { }
    protected override void SolveInstance(IGH_DataAccess DA)
        double data = 0;
        if (!DA.GetData(0, ref data)) return;
        // Get the nickname of the target receiver
        string targetNickname = "ReceiverNickname";
        // Find the remote component with the given nickname within the cluster
        GH_Component targetComponent = null;
        foreach (IGH_DocumentObject obj in OnPingDocument().Objects)
            if (obj is GH_Cluster)
                GH_Cluster cluster = obj as GH_Cluster;
                foreach (IGH_Component clusterComponent in cluster.ClusterObjects(true))
                    if (clusterComponent.NickName == targetNickname && clusterComponent is GH_Component)
                        targetComponent = clusterComponent as GH_Component;
                        break;
        // Check if the target component was found
        if (targetComponent != null)
            // Send data to the target component
            targetComponent.Params.Input[0].AddVolatileData(new GH_Path(0), 0, data);
        // Expire solution to update the changes
        ExpireSolution(true);
    public override Guid ComponentGuid
        get { return new Guid("GUID_HERE"); }
Sender:
using System;
public class ReceiverComponent : GH_Component
    public ReceiverComponent() : base("Receiver", "R", "Receive numeric data from sender", "Test", "Data") { }
    protected override void RegisterInputParams(GH_InputParamManager pManager) { }
        pManager.AddNumberParameter("Data", "D", "Received numeric data", GH_ParamAccess.item);
        double data = 0;
        // Receive data from the sender component
        DA.GetData(0, ref data);
        // Do something with the received data...
        // Output the received data
        DA.SetData(0, data);
    public override bool Read(GH_IReader reader)
        // Perform any additional reading here if needed
        return base.Read(reader);
    public override bool Write(GH_IWriter writer)
        // Perform any additional writing here if needed
        return base.Write(writer);
    protected override void ExpireDownStreamObjects()
        // Expire downstream objects to trigger a re-computation when data is received
        OnPingDocument().NewSolution(true);
        base.ExpireDownStreamObjects();
Thanks!
