I don’t think you can install packages into ironpython unless they are pure Python packages which you can just put into your site packages folder.
You can print from rhino with rs.command(). For example:
Otherwise you will need to access .Net methods - I don’t know anything about .Net so can’t help you here.
this seems like a bit of a long walk to get the default printer from within a GHPython component…but it works.
clr.AddReference("System.Management")
from System.Management import ManagementObjectSearcher
DefaultPrnt = []
OtherPrnt = []
objMgt = ManagementObjectSearcher("Select * from Win32_Printer")
for result in objMgt.Get():
if result.GetPropertyValue("Default") == True:
DefaultPrnt.append(result.GetPropertyValue("Caption").ToString())
else:
OtherPrnt.append(result.GetPropertyValue("Caption").ToString())
a = DefaultPrnt
b = OtherPrnt
import win32print, win32ui, win32gui
import win32con, pywintypes
# create a dc (Device Context) object (actually a PyCDC)
dc = win32ui.CreateDC()
# convert the dc into a "printer dc"
# get default printer
printername = win32print.GetDefaultPrinter ()
# leave out the printername to get the default printer automatically
dc.CreatePrinterDC(printername)
# you need to set the map mode mainly so you know how
# to scale your output. I do everything in points, so setting
# the map mode as "twips" works for me.
dc.SetMapMode(win32con.MM_TWIPS) # 1440 per inch
# here's that scaling I mentioned:
scale_factor = 20 # i.e. 20 twips to the point
# start the document. the description variable is a string
# which will appear in the print queue to identify the job.
dc.StartDoc('Win32print test')
# to draw anything (other than text) you need a pen.
# the variables are pen style, pen width and pen color.
pen = win32ui.CreatePen(0, int(scale_factor), 0)
# SelectObject is used to apply a pen or font object to a dc.
dc.SelectObject(pen)
# how about a font? Lucida Console 10 point.
# I'm unsure how to tell if this failed.
font = win32ui.CreateFont({
"name": "Lucida Console",
"height": int(scale_factor * 10),
"weight": 400,
# again with the SelectObject call.
dc.SelectObject(font)
# okay, now let's print something.
# TextOut takes x, y, and text values.
# the map mode determines whether y increases in an
# upward or downward direction; in MM_TWIPS mode, it
# advances up, so negative numbers are required to
# go down the page. If anyone knows why this is a
# "good idea" please email me; as far as I'm concerned
# it's garbage.
dc.TextOut(scale_factor * 72,
-1 * scale_factor * 72,
"Testing...")
# for completeness, I'll draw a line.
# from x = 1", y = 1"
dc.MoveTo((scale_factor * 72, scale_factor * -72))
# to x = 6", y = 3"
dc.LineTo((scale_factor * 6 * 72, scale_factor * 3 * -72))
# must not forget to tell Windows we're done.
dc.EndDoc()
