This post may interest some designers interested in the application of mathematics to library design.
A library is a stack of shelves for storing books. A perceived problem in standard library design is that the pattern can be perceived as a bit boring. The proposed solution to the boredom problem is to use a slightly irregular pattern.
The proposed solution leverages findings from mathematics in plane tiling with pentagons (see Pentagonal tiling - Wikipedia and https://www.quantamagazine.org/pentagon-tiling-proof-solves-century-old-math-problem-20170711/). Indeed, mathematicians have devised 15 different types of tiling. One of them, the type 7, is intriguing for two reasons:
- its pattern is a fine mixture of regularity and disorder (see picture above)
- all edges can have the same length. Hence, if you drill holes on each edges at the same place, holes of adjacent edges will match, leading to a simple assembly solution.
Note: the attached GH definition was developed with rhino for mac.
pentagon tiling type 7 v11.gh (32.1 KB)
