Hi, I need to join 3 rectangles with a bounding box but the new command does not work as the previous one which could be set to one box with a toggle. How can I solve this?
Thanks in advance,
Patricia
pretty cryptic but i believe if you right click on the component and change it from Per Object to Union Box is what you need.
Pufferfish’s Bounding Rectangle takes a Boolean toggle if that’s what you need.
thanks a lot!
It´s fine now!
Best,
Patricia
