GetPoint Loop with options. When clicking on options in commandline, each time a new point is created on the canvas near the commandline. Also, when not using the RhinoApp_EscapeKeyPressed function, a point is created when pressing ESC.
What am i doing wrong?
Thanks
points.Clear();
while (true)
m_escape_key_pressed = false;
RhinoApp.EscapeKeyPressed += RhinoApp_EscapeKeyPressed;
GetPoint getPoint = new GetPoint();
getPoint.SetCommandPrompt("Please select point");
var boolOptionAxis = new Rhino.Input.Custom.OptionToggle(front, "Front", "Side");
getPoint.AddOptionToggle("MirrorPlane", ref boolOptionAxis);
var boolOption = new Rhino.Input.Custom.OptionToggle(clamped, "Off", "On");
getPoint.AddOptionToggle("Closed", ref boolOption);
if (points.Count > 1)
getPoint.DynamicDraw += DynDrawCurve;
getPoint.AcceptNothing(true);
if (getPoint.Get() == GetResult.Nothing) break;
if (m_escape_key_pressed) break;
clamped = boolOption.CurrentValue;
front = boolOptionAxis.CurrentValue;
if (front == false)
xm = -1;
ym = 1;
if (front)
xm = 1;
ym = -1;
Point3d pt0 = getPoint.Point();
Point3d pt0M = new Point3d(xm*pt0.X, ym*pt0.Y, pt0.Z);
int insert = points.Count / 2;
points.Insert(insert, pt0);
points.Insert(insert+1, pt0M);
NurbsCurve nc = NurbsCurve.Create(clamped, 3, points);
RhinoApp.EscapeKeyPressed -= RhinoApp_EscapeKeyPressed;
doc.Objects.AddCurve(nc);
doc.Views.Redraw();
return Result.Success;
