I’m playing around with the script posted in the forum here and I am trying to add a command line option.
When running the script, changing an option triggers the GetPoint event, even though I don’t select a point with a mouse click. Also, the resulting point is always this:
-1.23432101234321E+308,-1.23432101234321E+308,-1.23432101234321E+308
Is there a way to prevent this from happening? Maybe I have something out of order.
import Rhino
import scriptcontext
from System.Drawing import Color
def DoSomething():
radius = 5
optionRad = Rhino.Input.Custom.OptionDouble(radius, True, 0.5)
mesh_id = rs.GetObject("Select mesh", 32, True, False)
if not mesh_id: return
mesh = rs.coercemesh(mesh_id, True)
plane = Rhino.Geometry.Plane.WorldXY
tolerance = scriptcontext.doc.ModelAbsoluteTolerance
radius = 4.0
gp = Rhino.Input.Custom.GetPoint()
gp.Constrain(mesh, False)
gp.Tag = None
gp.SetCommandPrompt("Point on mesh")
gp.AddOptionDouble("Radius", optionRad)
radius = optionRad.CurrentValue
def GetPointDynamicDrawFunc(sender, args):
plane.Origin = args.CurrentPoint
circle = Rhino.Geometry.Circle(plane, radius)
curve = circle.ToNurbsCurve()
rc = Rhino.Geometry.Curve.ProjectToMesh(curve, mesh, plane.ZAxis, tolerance)
if rc.Count != 0:
args.Display.DrawCurve(rc[0], Color.Red, 3)
sender.Tag = rc[0]
gp.DynamicDraw += GetPointDynamicDrawFunc
getres = gp.Get()
if gp.CommandResult() != Rhino.Commands.Result.Success:
return None
if gp.Tag:
crv_id = scriptcontext.doc.Objects.AddCurve(gp.Tag)
rs.SelectObject(crv_id)
gp.Dispose()
if __name__=="__main__":
DoSomething()
