GetMultiple to highlight only selected BrepFaces in block instance
During object selection, is there a way to have RhinoGet.GetMultipleObjects or Custom.GetObject.GetMultiple highlight only the selected BrepFaces instead of the entire brep when the latter is within a block? The GIF on the left shows the behavior that I want but for face selection.
SelEdges SelFaces
SelBrepCompsWithinBlock.3dm (59.1 KB)
import Rhino
import scriptcontext as sc
def main():
    rc, objrefs = Rhino.Input.RhinoGet.GetMultipleObjects(
        "Select edges",
        acceptNothing=False,
        filter=Rhino.DocObjects.ObjectType.Curve)
    if rc != Rhino.Commands.Result.Success: return
    for objref in objrefs:
        crv = objref.Curve()
        sc.doc.Objects.AddCurve(crv)
    sc.doc.Views.Redraw()
if __name__ == '__main__': main()
import Rhino
def main():
        "Select faces",
        filter=Rhino.DocObjects.ObjectType.Surface)
        face = objref.Face()
        brep_Out = face.DuplicateFace(duplicateMeshes=True)
        sc.doc.Objects.AddBrep(brep_Out)
Thank you
Hi @spb,
I am not sure there is a way. Do you know of any commands that allow for this?
– Dale
I couldn’t find any. Thanks.
