Get the value of Grasshopper component from RhinoPython
I am trying to program to set values in RhinoPython and get the resulting values calculated in Grasshopper.However, I don’t know which method to use to get the values of Grasshopper components.What should I do?
test.py (474 Bytes)
test.gh (9.4 KB)
Self resolved.
I worked around the problem by using the GhPython component to output the number component values to a txt file and reading it in.
hello 春日_拓実,
same problem here. i want to send data to grasshopper and to get back the computed solution with a single pythonscript. may you explain, how your solution is working?
best, heiko
Will this method work? Calling grasshopper components from within Rhino.Python:
Thanks for your reply. i’ll take a try. is this also usable with addon components (dendro in my case)
Yes, it should work for GH plugins also.
sounds promising, i will follow up on it!
