Get the normal of a line
Hello
I need to get the normal projected onto a line each “X” line segments.
For example, in the picture I should get the normal projected on the corner lines.
To divide the line into segments I use:
Line.ToNurbsCurve () DivideByLength (10, true).;
But for each segment, I don’t know how calculate the normal
I’m using c # and RhinoCommon
Find the closest point on the surface using Rhino.Geometry.Surface.ClosestPoint. Then use Rhino.Geometry.Surface.NormalAt.
If you are dealing with a planar curve, then you can also find the normals using
1- The curve plane normal (v1),
2- The tangents to your curve at each divide point (v2, v3, etc.),
Then calculate the normals using the vector cross-product operation (v2xv1, v3xv1, etc.)
And, How I can get the plane?
For example, in the image, I need calculate the normal of two lines in different planes.
The following shows a sample GH script and C# sample. I hope this helps.
CrvNormals.gh (8.7 KB)
Hi again,
I reopen this post _:slight_smile:
With your code, the line’s direction determines the normnal’s direction. For example. In the Image
The normal of Line 1 is outside and the Line 2 is inside.
I’d like get some similar at command _Dir
Select a Brep Object, and in a determinated Brep point get the normal. Something like this image
With the command _Dir
Try this
    ObjRef cRef;
    Result res = RhinoGet.GetOneObject("Select BREP", false, ObjectType.Brep, out cRef);
    if (res != Result.Success)
        return res;
    Brep b = cRef.Brep();
    GetPoint gp = new GetPoint();
    gp.SetCommandPrompt("Select point for normal");
    while (true)
        GetResult gr = gp.Get();
        if (gr != GetResult.Point)
            break;
        Point3d pt = gp.Point();
        Point3d closest;
        ComponentIndex ci;
        double s, t;
        Vector3d normal;
        if (b.ClosestPoint(pt, out closest, out ci, out s, out t, double.MaxValue, out normal))
            doc.Objects.AddLine(closest, closest + normal);
            doc.Views.Redraw();
            RhinoApp.WriteLine("Normal is :"+normal);
    return Result.Success;
It works perfectly!!
Thank you very much!
