Hi there!
I’m trying to modify my “Launch Transparent Window”, by removing the drop shadow. I saw this reply about Get/Set Element properties for a Toggle component and wondered if I could do the same thing to a Window.
However I get an error message on the “Get Element Properties” Component: Solution Exception:specified cast is not valid.
Is there a work around to this?
Thank you Kindly!
