Get current material selection from render library panel
Is there a way to programmatically get the current selection of the render material in the Render Libraries Panel?
https://developer.rhino3d.com/api/rhinocommon/rhino.ui.panels/getpanel#(guid,rhinodoc)
this method^ returns an object type (render library panel) which I cant interact with.
it exposes a bunch of properties but I am havent been able to find current selection in there yet.
Thanks
Srujan
Hi @svichare, does below help ?
Note: the panel id i have for render library seems different than yours and there could be multiple selections in the thumb viewer…
RenderLibrarySelectedItems.py (1.6 KB)
_
c.
Thanks for that. reflection helped!
I am making a command so translated this to C#
