Hi
- Drag and drop files to attach in a master document (current file).
In the File Options chose Attach File. All is correctly imported - Save the master document, (save is done), Quit.
- Open the master document.
The attachements are not saved
Hi
Hi Piem - thanks, I’ll check this - for now, please open Worksession and save an rws file from that dialog - that file is what holds the attachment info - you should be prompted to save that on closing.
I added this thread as a reference to https://mcneel.myjetbrains.com/youtrack/issue/RH-44773
thanks,
The prompt dialog only ask to save the document, not the working session.
But the work is done if you remember to save the rws.
