help to create a Feature Control Frame
Hi, I want to ask if there is a way to create this kind of specifications inside rhinoceros.
The requirement is that the part assembly must pass an axis through the hole and surfaces A and B are parallel and make contact.
With the specified dimensions, if the components are manufactured as specified, will the requirement be met in all conditions under which the components are manufactured?
I have done a lot of research trying to get the icons to be able to defend myself a little bit on that topic, but I got a little bit confused.
Is there any script that uses something similar to the icons shown in the second image at the bottom to place icons in a more practical way to recreate something like the first reference image?
Iconos_.3dm (124.7 KB)
