I’m a novice user of Grasshopper, and I’m currently trying to create a crystal growth on an existing Rhino model using Grasshopper. I’ve tried other crystal definitions on here but I keep running into error messages. (Maybe because I’m using Mac/not the right plugins?) I would really appreciate the help!
crystalchair.3dm (3.6 MB)
https://discourse.mcneel.com/t/beginner-help-making-a-geode-pattern/118737
https://discourse.mcneel.com/t/a-plugin-or-definition-dealing-with-crystalline-growth-like-a-geode/110137
Hello it is very hard to help you.
What are these messages (screen copy, text copy …)
Which output do you intend to do ?
The current one is this message, about the Ngon plugin, and then my file crashes. I intend to create a 3dm file for rendering, I don’t intend to 3D print or anything. (Sorry if I misunderstood the question!) I guess I just want to know if it is an issue with my file or with my computer, which is a bit old. If necessary I can borrow a better one.
Message log start (chronological):
Plugin version: 1.0.0007
Input parameter chunk is missing. Archive is corrupt.
Object list read
Hello
Ngon is not mandatory, just 2 years ago it was working better than some other tools. So change it by triremesh and it must work better, I hope because I am not on Mac so some tools could not work.
20221020_crystal growth perfect crystal.gh (393.5 KB)
Thank you so much for your patience and for the original crystal definition, this worked well!
