Generating G-code from Grasshopper — Start/End code
Has anyone here worked with generating G-code directly from Grasshopper?
I’ve been exploring this workflow and tried studying the Advanced 3D Printing with Grasshopper resources. However, I feel there is still a significant knowledge gap — especially regarding how to properly structure the start and end G-code, as well as handling temperature control and filament extrusion logic.
Most examples focus on toolpath generation, but the printer initialization, shutdown routines, and extrusion calibration are not clearly explained.
I’m particularly interested in understanding:
• How you define reliable start and end sequences when exporting from Grasshopper• Best practices for managing nozzle and bed temperatures inside custom G-code• Strategies for controlling extrusion (E values, flow consistency, retraction, etc.) when the code is generated parametrically
If anyone has experience, references, or workflows to recommend, I’d really appreciate the guidance.
I have some experience in 3D printing with Gcode generated in GH, but I’m printing clay, not plastic… so we are in very different scenarios :slight_smile:
there are dozens of tweakable settings for FDM that probably won’t affect that much a clay printing, and -generally speaking- clay printing is for sure be much (MUCH) more forgiving
this said, what I see most people doing is take the code start/end from existing Gcode programs that print very very well in their 3D printing machine, I think that is a good starting point
Check out OvenBird Plug-in of food4rhino. It allows conversion of curves into g code, and overall one of the best things i have found for 3d printing.
for managing nozzle and bed temperatures = these are hardcore number, you just need to put it, you can use any suitable“Prm → input“
E values, flow consistency, retraction → for each material these values are different so you can make group of inputs.
