Generate some closed sketches with 1 diameter change
I test actually grasshopper, and i would like draw a serie of tools for measure differents diameters.
copy one sketch, and modify only 1 diameter
list of diameters for exemple : 5,6,7,8,9
you can find my file test on attachement
Is-it possible to add a text on each sketch generate ?
Thank you
Arnaud
grassHopperFile_measureDiameter
This is possible but I’m not going to download a file from a Google Drive.
Next time just drag and drop your file into a post please.
Below is a definition with two ways to create diameter dimensions with native Grasshopper components.
circles_diameter.gh (21.0 KB)
Thank you very much for your answer, i will test that.
If you want, i attach the file
copyWithModify1Diameter.gh (13.0 KB)
Capture d’écran 2022-11-05 173246
Best regards
Arnaud
This is probably more than you expected but I think it’s a better way to construct these tools. I just noticed that the larger diameter holes make those tools longer. There is a way to fix that
 :thinking:
copyWithModify1Diameter_2022_Nov5a.gh (19.8 KB)
Here is one way to make them all the same length (white group):
copyWithModify1Diameter_2022_Nov5b.gh (20.4 KB)
We might as well do hex wrenches while we’re at it, eh?
UPDATE: set bottom point ‘Y’ to ‘End_R’ slider value.
HexWrenches_2022_Nov5aa.gh (25.2 KB)
Hi Joseph,
it’s very great, thank you for your proposition to have the same lenght for all, i will modify after.
Thanks to your solution i
had make my project succesful.
copyWithModify1Diameter_2022test.gh (15.3 KB)
Just i would add the good text (diameter “mm”) into the each pieces, how i can make that ?
Best regards.
Thanks
billyetnono
Do you mean a label on each piece showing the size/diameter? This image is too small so I didn’t notice that detail:
You can use Text Tag 3D like this:
But as you can see, you’ve missed some details from my code. Look again.
copyWithModify1Diameter_2022_Nov6a.gh (25.8 KB)
Hi @Joseph_Oster ,
Thank you for your help, the holes are designed fir attach pieces together,
It’s for make inside diameter gauge.
like that :
My final file :
MesureDiametreInterieur.gh (21.7 KB)
I understand the design logic better with Grasshopper.
Thank you for taking the time to help me.
Have a nice day !
So I constructed the wrong thing
 :man_facepalming: Your images are too small.
P.S. Here is something that looks similar but works very, very differently?
inside_diameters
A “Taper Gauge”:
https://www.motionindustries.com/products/sku/02047005
