I added ‘align’ sliders to each of the yellow groups to set rotation offsets that align the gears without affecting gear ratios. It’s easy to see many ways this complex mechanism can fail! The two ‘rotating small circles’ each require their own ‘align’ slider and all of the gears attached to the blades must also be aligned separately to fit the large ‘inner circle with teeths’, independent of the blades! (that’s critically important) I added one ‘align’ slider that affects them all but that won’t do the job.
gear_isir_mechanism_2018Jan23b.gh (72.9 KB)
Looking more closely, I see that in the first group at the top left (‘size of blade’s teeth’), you are scaling one tooth but using an off-center reference? The tooth appears to be distorted?
Finally, I have to wonder if it’s a good idea to have the driving gear (blue group ‘rotating bigger circle’) move only 30 degrees? Many teeth are never used. Would it be better instead to have the ‘rotating bigger circle’ connect directly to the ‘outer circle main gear’ (which rotates only 3.8 degrees), driven by a small gear on the motor? Or some other arrangment, maybe skipping the ‘rotating bigger circle’ and driving one of the two small gears directly?
