hello,
I’m using Galapagos for the first time (on Mac and rhino 7), I’m using it with ladybug to try and minimise the sunlight hours with a pergola.
Galapagos is running and it’s on full display, I can see the results changing in rhino, but the things is that in the Galapagos window I can’t see the results themselves and I cannot reinstate them, they aren’t available.
Galapagos ran for 9 generations on my Mac without recording the results.
(I ran it on another computer and all was well, and I tried many times on my Mac and nothing changed)
why does this happen? and how can I fix it?
thanks in advance
Hi Eden -
Is this specific to running a Galapagos optimization on a Ladybug solution or does it also happen when you use the Galapagos solver in a definition that only uses standard Grasshopper components?
Hi Wim,
It specifically happened with ladybug. I’ve tried another code with only standard grasshopper components and it showed the solutions.
Thanks,
Eden
Thanks, Eden -
In that case, I’d check in the Ladybug Tools forum: https://discourse.ladybug.tools/
Thank you so much! I’ll check the forum
Thanks!
eden
