Hi, getting confused on something that might be easier than I thought but after reading some post here I couldn’t find the solution so trying with this post. I’m trying to join as one brep a multiple intersecting surface that have been piped in order to later use it as one geometry and using ‘flow’ to follow a path… but so far I could not find the solution. I’m sharing some screen and the data if someone has an answer. Thank you.
Hi, I apologize for the lack of information. Gabion walls are a type of retaining wall made with visible wire mesh and boulders (see picture below). My goal was to control the initial geometry and then array the shape along the curve. The wall I’m currently working on is quite high, which is why I tried to maintain certain default dimensions. Please see the attached current 3D picture version. Regarding the unrecognized plugin, I thought using the grid structure from Lunchbox would be easier.
Hi, did you ever figure it out? I am doing something similar for my class and have a 1000 foot height fluctuation gabion wall. What was the solution to recreate it on a curved extruded surface?
