Furniture/Element Styles being a strange
Hello, so I am an architecture student in Sweden, who currently got VisualArq not too long ago and am playing around with it in one of my projects, and for some reason it seems like the Furniture/Elements are being a bit funky and now adding sides to most of the objects, such as the cabinets, wardrobe etc. "attached a photo at the bottom, and I cant see to figure out how to make it so they are there! Hopefully, one of you has some ideas about the issues!
Kind Regards P
Hi @Smushy,
This error has occurred since a recent Rhino 8 update. This update fixes a bug in Grasshopper that affected these objects, which are created as Grasshopper Styles. Before this fix, the objects were incorrectly generated but appeared to work fine, so we hadn’t detected the issue. We will fix the templates in the next VisualARQ update. In the meantime, you can import the corrected styles from this file.
Furniture and Elements NEW - meters.val (1.5 MB)
Run the vaStylesImport command to import them and overwrite the existing ones.
Fantastic, thank you, Francesc! This fixed it!
Hi @Smushy I just let you know (and also to others that stumble into this issue), that we have fixed this issue in the VisualARQ library in the 3.4 update version. Update - VisualARQ
