I am looking for some help with creating a function in Grasshopper where I am adding two numbers. What I want is this: if the sum of two values is greater than x, then the output value = x. But if the sum is less than x then the output is whatever the sum is.
Example:
If X is 120
Then 100+30 would output 120
Or 100+10 would output 110
Just not sure how I would create a function node that returns this as a single output
