geopattern.pdf (7.2 MB)
Hello!
After reading a document about geodesic patterns (references attached) and ways of getting them, i’m trying to replicate one of the methods explained in this document which is the “sharpening” method on a grasshopper algorithm. The method consist in getting the vectors field of a surface and apply the “sharpening” method to get boundaries which will divide the “boy surface” into patches for fabrication purposes.
I tried first to get the vectors field using one of the algorithms by @DanielPiker (Principal curvature approximation on meshes) but didn’t work well (not sure if the input should me a mesh and not a surface as i did).
Second i looked over the internet to find more about the “sharpening” process applied in grasshopper algorithm but almost found nothing about that!
Any hints or help in that?!
Fares
