Hello All,
Thickness analysis is a useful command in Rhino, but the result isn’t - let’s say - “geometrically usable”.
It would be awesome to have something in Grasshopper that takes a solid and - by adjusting a parameter (which is the thickness) - can result in a geometrical output (curves).
So, taking the example below, if the input parameter is “1” the output is all the curves laying on the green region where the thickness is exactly 1mm.
Test.3dm (83.7 KB)
Any thoughts?
Thank you!
