Hi.
I am a newbie in the Rhino world and I need to convert the 2D curve from an image in 3D/2D points. Any suggestions in the form of tool / plugin?
Thanks.
Hi.
Thanks.
Hi Miguel,
Welcome! If you have imported a point file or acquired points through a digitizer, You can use the command CurveThroughPt to draw a curve through the points selected. There are also Point Osnaps enabled at the bottom of the interface which would allow you to pick the points when using the InterpCrv command if the curve needs to touch each of the points.
Thanks a lot!
