Fountain Grasshopper Test Scene
I created this scene to test some grasshopper scripts for boulder walls, curbing and fences. I also used the scene to test some ideas for quickly building out backgrounds in D5 Render.
These are lovely, thanks for sharing-
Personally I’d love to see a bit more drama in the perspective by changing the rhino camera to 35 mm instead of the default 50mm
Hi Marvin, I just found that thread.
Quite impressive work, I really like it!
So do you mind sharing a little bit about how you managed to create all these individual kerb stones following a spline? Are these automatically generated by grasshopper?
Thanks
Andy
Thanks @theoutside I’ll give this a try on my current project.
Thanks @walther The curb object is a rounded box modeled in Rhino. The curb object is then referenced in Grasshopper, Grasshopper then generates copies of the curb following along the path. The Grasshopper script can use multiple curb objects and randomly vary them along the path and there are scale controls in the grasshopper script to control the size of the curbs.
